PrusaConnect camera with raspberry pi + curl
Florian Castellane
(@florian-castellane)
Utenti
I'm trying to use this thread as a reference together with the prusa connect camera api reference and  to register a camera with curl, but keep getting
{"message": "Missing or invalid security token", "code": "UNAUTHORIZED"}
My request:
curl -X POST \
  -H "token: <token from  https://connect.prusa3d.com/printer/<my  printer uuid>/cameras>" \
  -H "fingerprint: <name of the camera in  https://connect.prusa3d.com/printer/<my  printer uuid>/cameras>" \
   https://connect.prusa3d.com/app/printers/<my  printer uuid/camera?origin=OTHER
 I think I just didn't understand what the token and fingerprint are. These are given here right? I guess the fingerprint is the camera name, and the token is what is given here.
Can you see what I am doing wrong here?
Postato : 23/01/2024 6:53 am
Florian Castellane
Utenti
RE: PrusaConnect camera with raspberry pi + curl
never mind, the service seems to be down at the moment...
{"message": "Service is unavailable at this moment. Try again later", "code": "SERVICE_UNAVAILABLE"}
Postato : 23/01/2024 7:14 am
Florian Castellane
Utenti
I got it to work. The TOKEN is not the same as the QR code it seems, you have to grab that as well from the web app. Here is some code to make it work with rpicam-still:
#!/usr/bin/env bash
set -Eeu
set -o pipefail
shopt -s extdebug
FINGERPRINT="changeme"
TOKEN="changeme"
trap 'declare rc=$?;
      >&2 echo "Unexpected error (exit-code $rc) executing $BASH_COMMAND at ${BASH_SOURCE[0]} line $LINENO";
      exit $rc' ERR
main () {
  while true
  do
    if rpicam-still -t 1 -o - \
    | curl   https://webcam.connect.prusa3d.com/c/snapshot   \
      -X PUT \
      -L --fail-with-body \
      -H "Content-Type: image/jpg" \
      -H "Fingerprint: $FINGERPRINT" \
      -H "Token: $TOKEN" \
      --data-binary @-
    then
      printf "."
    else
      echo
      echo "?"
    fi
    sleep 30
  done
main "$@"
Postato : 24/01/2024 9:29 am
timzilla
(@timzilla)
Just adding here that the camera fingerprint seems to be a generated UUID.   `uuidgen` in your shell, or any uuid generator should be able to create one.  no need to go through the prusa QR flow.
Postato : 04/02/2024 5:23 pm
Kopr
 Kopr
(@kopr)
Utenti
Follow the guide in my project and you should get it working without any problems
https://www.printables.com/model/989624-prusa-enclosure-raspberry-pi-camera-modification-w
Postato : 16/11/2024 7:42 am
eloekset
(@eloekset)
Utenti
I had the camera API working from a Raspberry Pi for a while, but the SD card died and when I try to set it up again, I just keep getting the response {"detail":"Invalid fingerprint"} no matter what value I specify for fingerprint. Well, if it's shorter than 16 characters, I get another error message telling me that, but anything more than 16 characters seems to be invalid.
Every search result tells me that this value can be any random string, but then why do I get that error message? There must be something that's not documented about this fingerprint value.
Postato : 17/04/2025 6:28 pm
_KaszpiR_
(@_kaszpir_)
Remove camera and register it again, because you cannot change fingerprint after camera registration.
Fingerprint can be vey easily generated by cli tool 'uuidgen'.
Postato : 17/04/2025 8:58 pm
1 persone hanno apprezzato
Kopr
 Kopr
(@kopr)
Utenti
Posted by: @eloekset
I had the camera API working from a Raspberry Pi for a while, but the SD card died and when I try to set it up again, I just keep getting the response {"detail":"Invalid fingerprint"}…
Delete the camera from Prusa Connect, create a new one and use the new API Key and new fingerprint.
 My script mentioned above does generate the fingerprint from the device (RPi) so it’s stable between runs, but still (mostly) unique for the board Hardware.
Postato : 18/04/2025 1:57 pm
