Prusa XL dual tool and changing heads from Connect
2pucks
(@2pucks)
Hi - very new user here (both to 3D printing and Prusa Connect)... I currently have PETG in toolhead #1 and toolhead #2 has PLA (that came with the printer) loaded. The filaments/heads seem to be correctly set on the control panel.
With both heads parked (ie on their holders) if I send a gcode file with PETG selected from Slicer to the printer, it goes into 'attention' mode and nothing will fix that (remotely). If I send the same file but with PLA selected, it selects head #2 and starts printing the file just fine.
Is there no 'select toolhead settings' or the alike remotely? Do I have to check all this from the console?
Also if the printer is showing "attention" (due to the filament type in the file) is there no way to correct/override this from Connect?
Thanks... searching on these topics brings up nothing related to the Prusa XL, probably because it's still so new.
Posted : 15/09/2023 12:25 am
RakkyJC
(@rakkyjc)
Multitool XL is not yet support in connect. Thay are working on it.
Posted by: @tojik
Hi, the FW team did an awesome job with the new MMU firmware. Now the ball is in our court. I need to implement the mmu monitoring code and Connect will need to figure out a way to show the MMU and multitool XL in a user friendly way. That has not happened yet. Sorry
https://forum.prusa3d.com/forum/introcuctions-instrutctions/prusa-i3-mk3s-with-mmu2s-support/paged/2/#post-669006
This post was modified 2 years ago by RakkyJC
Posted : 20/09/2023 12:27 pm
