Prusa Link error on Prusa Slicer 404
SemichCSC
(@semichcsc)
Each time I try to print from the prusa slicer, to prusa link I now get: PrusaSlicer encountered an error: Error uploading to print host: HTTP 404: 404: Not Found.
It was working fine. I rebooted my PC and the printer, same issue.
Although I see the error, the print start normally on the printer.
Any clue?
Best Answer by Tojik:
Welp, you being able to reproduce it every time, does not mean we can. Anyway, it should be fixed and will be in the 5.0.0 release, but it most likely did not make it into the input shaper alpha
/Serge
Napsal : 29/05/2023 9:59 am
1 lidem se líbí
Tojik
(@tojik)
Member Moderator
RE: Prusa Link error on Prusa Slicer 404
We know about the error. It's not been easy to hunt down tho. I've seen some fixes being attempted but I am not sure if a fix is in an upcoming FW update or not.
Napsal : 01/06/2023 4:53 pm
1 lidem se líbí
SemichCSC
(@semichcsc)
Thks, what do you mean by hunt to? I can repro this everytime, happy to provide any log or a wireshark trace if it helps.
/Serge
Napsal : 04/06/2023 7:34 pm
Tojik
(@tojik)
Member Moderator
Napsal : 05/06/2023 9:51 am
1 lidem se líbí
SemichCSC
(@semichcsc)
Thank you for the details! Much appreciated
/Serge
Napsal : 05/06/2023 9:52 am
camolito
(@camolito)
I've been having the same issue with PrusaLink on my MK4 while PrusaLink has still been working on my Mini.  Have tried rebooting the computer, restarting the printer, unplug and replug the USB, de-activate and re activate PrusaLink in the printer settings, and closing and reopening the PrusaLink browser tab all with no luck.
Today I removed some of the files from the USB drive and now it works to transfer files again.
Napsal : 18/11/2023 4:26 pm
1 lidem se líbí
Tojik
(@tojik)
Member Moderator
Hi, could you send me, or describe the files you removed? Any special characters in names? Or anything else unusual about the files worth mentioning, so we could try and reproduce the issue. Thank you
Napsal : 21/11/2023 10:52 am
camolito
(@camolito)
Sorry, I didn't pay close attention to which files I removed.  I do know there were not any special characters in the name, I don't use special characters in any of my gcode file names.  If I start to have the problem again I'll pay more attention to what I am removing and at what point transferring files starts to work again.
Napsal : 23/11/2023 3:00 am
Tojik
(@tojik)
Member Moderator
Thank you
Napsal : 23/11/2023 10:36 am
jay2jay99
(@jay2jay99)
Tojik, I just encountered this repeatedly and worked out it was the ‘%’ symbol that caused the transfer over Prusa Link to fail. Thought I’d pass it on in case it helps.
Jason.
Posted by: @tojik
Thank you
Napsal : 29/11/2023 9:37 am
2 lidem se líbí
J Ridgwell
(@j-ridgwell)
I realized I was getting this error because I had a double quote in the filename.
0.5" pipe connector
maybe the error code can be written to include the situations where illegal characters are used.
Napsal : 24/01/2024 8:17 pm
1 lidem se líbí
Valentine
(@valentine-2)
Yes! Thank you. That solved it for me.
Napsal : 23/08/2024 6:30 pm
magnetoprint
(@magnetoprint)
Hello Tojik, I still encounter the same problem when printing a file with " in the name.
Thank you to other posters in this thread who allowed me to solve the error.
Napsal : 30/09/2024 8:23 pm
Conrad
(@conrad)
I suddenly had to reformat the USB drive
Napsal : 03/11/2024 8:23 am
Steve Weathernam
(@steve-weathernam)
Posted by: @jay2jay99
Jason.
Posted by: @tojik
Thank you
I ran into this recently too. I would try to upload a file to Prusa Link and it would error out part way through. Removing the % character fixed it. But surely this should not be the case. Prusa controls the code. Surely they can determine which characters are, and are not allowed, in the names. Basically, I would vote to let pretty much all characters, except ones that are invisible on a display.
Napsal : 09/12/2024 6:51 pm
1 lidem se líbí
Steve Weathernam
(@steve-weathernam)
I also noticed something else. If a file that has a % character in the name is manually copied to the USB thumb drive using a computer, then the drive is reinserted into the MK4S display, the file can be seen by the printer and printed. The % only seems to be an issue when trying to upload the file.
This post was modified před 1 year 2 times by Steve Weathernam
Napsal : 09/12/2024 9:45 pm
VINNIE3000
(@vinnie3000)
In case anyone is searching for this issue and finds this post: I had the same error message and found out that a forward / or backward slash in the filename causes the error, remove it from the file name and it all works fine again!
Napsal : 28/05/2025 11:15 am
1 lidem se líbí
SteveS
(@steves)
Hit the same error here on my Mk3.5S (modified from Mk3s).. It was all working fine until i did a factory reset after replacing the hotend. Thought it would be the easiest way to reconfigure! Boy was I wrong!
I can load files to the printer via Prusa Connect or even the Physical Printer tab but when i try to upload from the Plater tab using the "G" button it throws an error. Says its resolving address and then lobs up "Error uploading to print host:HTTP 401: 401: Unauthorized". Addrees is obviously fine as it works through the other two tabs, dragging and drop the file. I can ping it from the laptop. Checked file names, no special characters. Nothing that's mentioned previously in the thread helps.
Any help?
Napsal : 09/06/2025 7:34 pm
