Print to Mk3.5 using PrusaLink via PrusaSlicer
mpeill
(@mpeill)
Maybe I'm missing somethig, but can't set up printing to Mk3.5 (upgraded Mk3S) from PrusaSlicer.
On my Mk3S I could print direct  from PrusaSlicer.
Now with Mk3.5, I can open PrusaLink in web browser and see the printer, but no "settings" option to obtain an API key. So when I try and add a physical printer in PrusaSlicer I can't enter the API Key, and hence not able to create the physical printer.
My only option is to print via USB memory stick. I can then watch the progress and stats via PrusaLink, but I don't want to keep moving USB sticks as a transfer method.
What am I doing wrong/missing? Should I be able to print directly from PrusaSlicer? Is there internal storage available in the Mk3.5, as there's no tab at the moment for this, only for USB?
Best Answer by Tojik:
Glad it's working
Opublikowany : 02/04/2024 9:44 am
Tojik
(@tojik)
Member Moderator
RE: Print to Mk3.5 using PrusaLink via PrusaSlicer
Hi, the physical printer configuration allows you to change the authentication type to HTTP Digest, then you can use the same name and password as you use to log into PrusaLink. Hope this helps
Opublikowany : 02/04/2024 10:19 am
mpeill
(@mpeill)
Thanks for the reply. I've changed to HTTP Digest and created the physical printer. When I try to then export from PrusaSlicer direct to printer, I get:
"Upload has failed. There is no suitable storage found at 192.168.1.76."  (This is the IP of PrusaLink that I can view)
Opublikowany : 02/04/2024 11:10 am
Tojik
(@tojik)
Member Moderator
Do you have the flash drive inserted and writeable?
Opublikowany : 02/04/2024 12:19 pm
mpeill
(@mpeill)
Doh, yeh, you're right. I was looking for the difficult answers and forgot to plug in the flash drive. Thanks for your help. All is now working via PrusaLink.
Opublikowany : 02/04/2024 2:14 pm
Tojik
(@tojik)
Member Moderator
Glad it's working
Opublikowany : 02/04/2024 4:05 pm
