Noob question I'm sure, but how do I delete Printer Files on Prusa Connect?
Chewie
(@chewie)
Hi all
As per title really. Is the only way to delete files I've sent from Prusa Connect to right click & delete? Is there not a way to do multiple files at once?
I'm only a month in to 3D printing so a lot of the files on Connect are print once & never again jobs, it very long winded having to get rid one at a time when I notice how many have built up. ☹️
Cheers all
Chewie.
Opublikowany : 18/12/2023 9:55 pm
RE: Noob question I'm sure, but how do I delete Printer Files on Prusa Connect?
Alas, this is one of those features surprisingly missing from Prusa Connect.
Opublikowany : 19/12/2023 2:06 am
Tojik
(@tojik)
Member Moderator
Yeah, the printer cannot hold more than one file path to delete in ram at this point, so we would have to go sequentially, deleting file after file after file. So you'd get a lag of several seconds to minutes when deleting a larger amount of files. It's really better if you just do multi deletions on something more powerful.
Also, multi deletion works for connect files. but beware of select all, it selects ALL and it selects it every time, no matter the search box or filters. We're fixing it, just don't accidentally delete everything
Opublikowany : 20/12/2023 12:58 pm
mageb
(@mageb)
Even with a progress bar lasting 30 minutes it would be much better to be able to delete multiple files with just a few clicks! The current state is a real pain. Having to click and wait in an annoying endless loop in order to get rid of 100 files...
Opublikowany : 10/09/2024 9:18 am
leonpalm
(@leonpalm)
Any changes to allow mass deletion of failed/complete transfers? It's very tiresome to delete one file at a time from from failed transfers.
Opublikowany : 27/02/2025 6:31 pm
