No printer in connect
MonoTovarisj
(@monotovarisj)
I went through the wizard, and everything went fine, however I might have forgotten to click the add printer on the last page of the wizard, how do I restart the wizard or add the printer manually to prusa connect?
Do I really have to flash the sd card on the pi and start all over?
Opublikowany : 03/01/2022 12:39 pm
jkavalik
(@jkavalik)
RE: No printer in connect
I just did the same mistake - did not click the final "add" button in Connect. A configured my ssh access so I was able to redo the wizard after deleting '/home/pi/prusa_printer_settings.ini' and restarting the rpi ('sudo reboot'). Without ssh you might be able to delete that file from a pc, but probably linux only - my windows machine can only see the boot partition, not the OS data.
Opublikowany : 03/01/2022 2:30 pm
1 ludzie polubili
MonoTovarisj
(@monotovarisj)
Ah I will try that, I enable ssh as well.
Came to add this screenshot of the error I found in settings in prusalink.
Opublikowany : 03/01/2022 3:40 pm
jkavalik
(@jkavalik)
Exactly what I was seeing - noticed in my config that the value of "token" in the "[service::connect]" section was missing too - it is now filled properly after the redo.
Maybe check that and offer re-registration?
Opublikowany : 03/01/2022 3:44 pm
MonoTovarisj
(@monotovarisj)
I deleted the file via ssh and run the wizard again and now it's working! Thank you for the suggestion.
Opublikowany : 03/01/2022 4:05 pm
SpeakingOfBrad
(@speakingofbrad)
In the PrusaLink install guide, it says to add /Wizard after the IPaddress to open up the setup wizard again.
Opublikowany : 05/01/2022 12:05 am
MonoTovarisj
(@monotovarisj)
Ah great tip, thank you
Opublikowany : 05/01/2022 9:22 am
