Miroslav's cool ESP32 CAM firmware setup...
moofie
(@moofie)
I'm working my way through the setup instructions, and I'm getting stuck trying to connect to Service AP Mode
https://github.com/prusa3d/Prusa-Firmware-ESP32-Cam?tab=readme-ov-file#arduino_cfg
I can't tell if the board is booting.  The flash LED is flickering faintly, but I'm unable to see the SSID when I search for wifi networks.  Anybody smarter about ESP32 than I am gotten past this point?  Is there another way to set up my network's SSID and password other than the Service AP mode?
Best Answer by moofie:
Flashed the boards from my Macbook Pro, and they work like a champ!  Thank you!
Publié : 05/05/2024 1:00 am
moofie
(@moofie)
RE: Miroslav's cool ESP32 CAM firmware setup...
Note that I got a reply on the github suggesting using another computer.  So now I have to figure out how to install esptool.py on a Mac...
https://github.com/prusa3d/Prusa-Firmware-ESP32-Cam/issues/12#issuecomment-2094531297
Publié : 05/05/2024 1:41 am
JP Guitars
(@jp-guitars)
If you turn on the serial monitor in the IDE you should get some feedback to what is actually happening and how far it is getting
Alternatively you could try getting a different software running, I used the one below which worked for me and I found his instructions pretty easy to follow. If you want to go back to Miroslav after you have checked everything else using johnyHV it's not a problem, whenever you push software to an Arduino it removes the previous software.
https://github.com/johnyHV/PrusaConnect_ESP32-CAM
Publié : 05/05/2024 9:08 am
moofie
(@moofie)
Publié : 05/05/2024 6:14 pm
Nova_Pony
(@nova_pony)
Membre
Hi! I am trying to run through this setup and am having trouble..
I cannot find where to dl this .zip file and how to open the driver (windows) to flash the ESP board. Almost seems like I should be able to click the text as a link, but it is not clickable
ReadMe here: https://github.com/prusa3d/Prusa-Firmware-ESP32-Cam/blob/master/doc/ESP32-Wrover-dev/README.md
Thanks for the help!
Ce message a été modifié il y a 2 years par Nova_Pony
Publié : 29/08/2024 5:54 pm
