[Poll] Do you have layer shifts when printing multiple PETG objects?
Do you have layer shifts when printing multiple PETG objects? Poll is created on Nov 15, 2023
Page 2 / 2
Wade
 Wade
(@wade)
RE: [Poll] Do you have layer shifts when printing multiple PETG objects?
i manually changed the z-hop from 0.2 to 0.4mm. I think this fixes the issue, dont have any layershifts after a couple of prints.
Thanks to point at this really easy solution. Its kind of obvious when you think about it, didnt know you can adjust the Z-hop hight. Thanks for the tip!
Publié : 18/03/2024 12:25 pm
1 personnes ont aimé
Wilmheath
(@wilmheath)
That's great news.  Have your PETG IS enabled prints been working well now?
Publié : 23/03/2024 6:56 pm
johndom123
(@johndom123)
Membre
It happened to me once, after I heard a *bang* and I suspect the nozzle collided with one of the parts and the Y-axis motor jumped steps.
This has also happened to me with an Ender 3 at work printing PLA, so I suspect a bug in the slicer sometimes rears its ugly head. Or if variable layer height is being used, perhaps it doesn't always keep clear of other instances of the part when moving from one to another.
Increasing the Z-hop distance will probably fix this as suggested.
If someone attaches a tiny camera and flex cable to the carriage looking at the nozzle, a lot of these issues will be made visible and sorted once and for all!
John Dom
Ce message a été modifié il y a 2 years par johndom123
Publié : 07/04/2024 10:43 pm
fabian
(@fabian)
Yes, I have when printing pla. Brand new kit, prints great, beautiful first layers. But layer shifts! What can i do? Do I have to disable IS? One of the main reasons for buying the expensive machine with lots of equal competitors. I´m not happy
Publié : 02/07/2024 2:24 pm
2 personnes ont aimé
Markus
(@markus-6)
Still observed with Slicer 2.8. In 2.7.4, I had repeated layer shifts with Prusament PETG when using Input Shaper, printing the same object without Input Shaper (yes, it takes twice as long) worked perfectly. First two attempts with IS in 2.8 failed again, no IS test is on the printer right now.
Since there are no non-IS profiles for the Mk4 with MMU3 - is there any way to disable the IS?
Publié : 03/07/2024 6:57 am
The usual causes of this sort of thing are warping and poor first layer adhesion.  Have any of you checked the underside of failed prints?
Publié : 03/07/2024 7:26 am
Markus
(@markus-6)
checking the ten or so failed prints in my wastebasket - nope, bed adhesion and print undersides are perfect. using the satin sheet, so any issues here would be quite obvious. same argumentation applies : why would IS prints fail reproduceably (but always at a different layer) while non-IS prints succeed?
going to run another attempt this afternoon - I'm using an obxidian nozzle, could be that what works for the slow speed is just not reliable any more at higher throughput. I'll try upping the temperature by a few degrees.
Publié : 03/07/2024 8:58 am
Hellboy383
(@hellboy383)
Membre
Yeah its getting pretty annoying, don't like input shaper due to failed prints but its the only option if you have an MMU
Publié : 06/07/2024 12:05 am
Mike B
(@mike-b-3)
Posted by: @markus-6
This seems somewhat logical (that it fails with IS more often):  IS results in faster speeds and more importantly faster acceleration on the X and Y axes, so any pulley (grub) screws that are marginal in their grip, or belt tensions that are marginal, will fail more often.  If your failures happen only in IS, that's the first place I'd look.
Once you've played with those (and I'd even adjust the belt tensions up and down from what appears to be the optimum, just to be sure), then you'd consider less obvious things like some kind of delays or non-linear behaviour of the filament being extruded (like maybe there's "filament momentum" when it's being extruded faster or something), or some other weird effect.   IS having bugs is also an option but many prints are succeeding and layer shifts would be exactly reproducible with the same gcode if that was the case.
Prusa MK4 since Jan 2024, Printables: @MikeB_1505898
Publié : 08/07/2024 7:14 pm
Antimix
(@antimix)
I had just one. I could say that printing in PETG is more difficult than PLA, and the speed should be kept slow due to low volumetric speed. I have the same issue sometime on the FLSUN V400 at high speed with PETG. However I know in advance when it is about to happen, since it happens only in specific conditions:
  • bad / humid PETG that has vapour or bubbles.
  • wrong infill type for the speed used. Gyroid is the best that does not cause problems. Rectilinear is the worst and creates irregular lines.
  • Strings that are present on the infill and on the perimeters.
  • Nozzle that start scraping the perimeters and the infill.
  • Material attached to the nozzle that starts scraping the just printed part, creating balls of material that enlarge themself and increase the material on the nozzle.
When those situation become true, you start hearing the nozzle scraping the infill, then the perimeters, and then you see the nozzle covered by plastic, until the plastic is big enough that it violently hit the object borders, since it could not move over the object any more, and then the layer could shift, or the object detaches from the bed.
Regards
Publié : 11/07/2024 11:17 pm
beltmatt_usa
(@beltmatt_usa)
Membre
I get this in PLA as well, it's very annoying to the point where I just use the "legacy" non-input profiles. I was hoping there would be a fix but I guess the input shaping just isn't there yet?
Maybe it will be working for more users with the S upgrade.
Publié : 19/08/2024 1:09 am
Wade
 Wade
(@wade)
Got a lot of layer shifts resently with petg, up to the point where no print is successfull.
In the end it looks like it cant print faster than my old MK3s, which is really dissapointing...
Publié : 06/10/2024 10:07 am
gerrrciu
(@gerrrciu)
Membre
It happens to me 1-2 times a month on two of the three MK4s. I thought it was because of the 3kg filament spools I use and sometimes when the printer pulls too hard it shifts but now I see that it's not just my problem. They print practically 24/7
Publié : 11/10/2024 7:23 pm
Colin T
(@colin-t)
Membre
Yes - My problems only started after I added the MMU3 to my MK4 which required me to also update the firmware to 6.1.3.  Before this, when I was running firmware 5.x.x. I had no problems at all.
Publié : 11/10/2024 8:18 pm
Wade
 Wade
(@wade)
I managed to get rid of all layershifts by buing a new print plate. The original Satin print plate was the issue, petg would not stick to it. It doesnt matter how hot (~100°C, messuered with 2 seperate infrared thermometers) oder how often i clean it with isopropanol.
I bought a new print bed from amazon and it works absolute fine, no more layershifts even with IS aktive.
Publié : 17/03/2025 12:08 pm
gerrrciu
(@gerrrciu)
Membre
Because a new build plate needs to be scrubbed with something rough, e.g. the hard part of a dishwashing sponge. And you definitely need to use some glue. In my case, it was 99.9% the firmware that was to blame. On 6.2.0 alpha1 I never had layershift. After updating to the non-beta 6.2.0 version, layershift was practically every two or three prints. When I re-uploaded the alpha1 version, I never had layershift. And it was the same on all three MK4s that I have
Publié : 17/03/2025 12:18 pm
Lime McMile
(@lime-mcmile)
Membre
I was having the same issue. I replaced the nozzle with a new one and completely recalibrated and everything worked well. I also cleaned the enclosure and all of the posts that the extruder slides on. I think that the printer might have been bumping something during a print and got misaligned, or it was misaligned when it was calibrated. I hope this helps.
Publié : 20/11/2025 11:28 pm
Page 2 / 2
