MK4 IS firmware doesn't speed up the benchy test
Using the latest RC firmware for MK4 as well as the latest IS profile in prusaslicer. A normal benchy slices and says it will take approx 40 minutes but the actual print time stays around 1 hour and 20 minutes. Do I need to do some sort of calibration after I install the IS firmware?
Veröffentlicht : 14/08/2023 5:43 pm
RE: MK4 IS firmware doesn't speed up the benchy test
No extra steps are required. Are you sure the firmware flashed correctly? The LCD should have "INPUT SHAPER" in the top left.
Veröffentlicht : 14/08/2023 5:58 pm
Did you find a solution? I have the latest firmware (input shaping shows on the LCD screen) and latest slicer (it shows input shaping profile too).
The bench from printables still takes 1h to print on .15
Veröffentlicht : 12/11/2023 1:12 pm
Thats what the slicer shows.
Veröffentlicht : 12/11/2023 1:18 pm
