Can we use the Input Shaper with the MMU3 ?
HappyKatz
(@happykatz)
The Input Shaper is one of the main reasons I would consider upgrading my MK3S+ to the MK4; however, my MK printer is also my MMU printer, and I'd like to be able to use these together.
Is there (or will there be) an Input Shaper profile for MK4 / MMU3 ?
Prusa Core One, MK4S w/ MMU3 (formerly MK4 / MMU3, MK3S+/MMU2), 2 Prusa MINI+, Octoprint. ASA, PETG, PVB, (some) PLA.
Postato : 22/08/2023 6:13 pm
kengineer
(@kengineer)
RE: Can we use the Input Shaper with the MMU3 ?
There is no MMU3 for the MK4.
Postato : 21/11/2023 6:35 pm
Hello
(@hello)
Posted by: @kengineer
There is it's just not been shipped yet
Postato : 21/11/2023 7:06 pm
kengineer
(@kengineer)
If something doesn't work and is not available is it vaporware or a thing?
Postato : 21/11/2023 7:07 pm
Brew
 Brew
(@brew)
I paid for it, therefore it's a thing. 😉 😀
Postato : 22/11/2023 12:53 am
3 persone hanno apprezzato
kengineer
(@kengineer)
I paid for one in July, it was a thing until Aug ship date listed in the ad then it became a future thing, now not sure
Postato : 26/11/2023 3:06 am
iftibashir
(@iftibashir)
I cant see why MMU3 would change anything - once the filament is loaded the print speed should continue as normal. As far as I can see, IS has no affect on the MMU3 loading/unloading process.......
Postato : 27/11/2023 11:25 am
1 persone hanno apprezzato
Zappes
(@zappes)
One could be unsure if the PTFE tubes, buffer etc. add too much drag on the filament, thus causing underextrusions. I don't think that's a risk, though - I run my filaments through lots of PTFE because of the way I set up my MK4, and the nextruder is quite unimpressed by that. 🙂
My models on Printables
Postato : 27/11/2023 11:27 am
Zfrenchy
(@zfrenchy)
the profile Input Shaper with MK4 MMU3 do not exist on the Wizard.
I have the same issue, MK4 with MMU3 and I cannot have the firmware for Input Shaper, BUMMER !
In this article from Prusa on July 2023, said the input shaper firmware will be compatible MMU3, WHERE IS THE FIRMWARE ?
Postato : 17/07/2024 9:38 pm
Ron
 Ron
(@ron-10)
Hope this helps you out ?
Regards, Ron
Postato : 18/07/2024 7:49 pm
John Lindo
(@john-lindo)
Can anyone explain "input shaper", I must of missed posts on this subject.
Thanks.
Postato : 21/11/2024 5:00 pm
