[Solved] basic question... 😀
thx4
 thx4
(@thx4)
basic question... 😀
hey there,
i am on newest firmware and app version.
i searched this forum and googled the f out of it but cannot get where to activate input shaper. i use a 0,4nozzle with an mk4 and prusament pla.
normally i use the base prusament pla presets (changed snug to organic). i have no configuration updates or app updates available.
do i get it wrong?
Napsal : 19/12/2023 9:17 am
RE: basic question... 😀
Have you loaded the profiles from Prusa Slicer Configuration Wizard?
Use the Structural Settings
Napsal : 19/12/2023 10:13 am
nhand42
(@nhand42)
Posted by: @jh-4
In PrusaSlicer go to Configuration -> Configuration Assistant -> Next. Top row will have your printer Original Prusa MK4 and you will have a ticked checkbox next to 0.4mm nozzle. Next to that will be another printer Original Prusa MK4 Input Shaper. PrusaSlicer treats Input Shaper as a completely different printer. Tick the checkbox for 0.4mm nozzle on it too and you now have two printers.
Click Next -> Next -> Next -> ... -> Finish. Now in the main window the Printer dropdown you can select your Input Shaper printer. If you have created a Physical Printer you can Edit Physical Printer and change its type from regular MK4 to MK4 Input Shaper. If you haven't created a Physical Printer don't worry about it, just use the Input Shaper system preset you are good to go.
Napsal : 19/12/2023 10:15 am
1 lidem se líbí
thx4
 thx4
(@thx4)
awesome. found it. thanks! glad to be part of the team.
Napsal : 19/12/2023 10:21 am
