5.0.0 Firmware for Original MK4/MK3.9 is out now!
Stránka 2 / 2
Tim
 Tim
(@tim-7)
RE: 5.0.0 Firmware for Original MK4/MK3.9 is out now!
I don't think that is the cause.  But could you please be more specific as to what pulley and why.  I am assuming you are referring to the x-axis.  But there are two ends; the drive/gear end and the tensioner end.  I am assuming you mean the tensioner end, which might be allowing slippage on the drive gear.  I did a quick check and the tension seems perfect.  But I will look into it more closely once you clarify.
Napsal : 13/10/2023 7:49 pm
Antimix
(@antimix)
Time to remove/update also this post... 😀
We are now to 6.0.3 😉
Napsal : 11/07/2024 11:01 pm
1 lidem se líbí
Stránka 2 / 2
