5.0.0-alpha4 Firmware for Original Prusa MK4
Same Old Shane
(@same-old-shane)
Membre Admin
Summary
  • Support for xBuddy revision
Firmware release 5.0.0-alpha4 for the Original Prusa MK4 is focused on adding support for xBuddy revision.
This firmware release is extending support for the upcoming xBuddy hardware revision. The system recognizes between the boards automatically and there is no need for user intervention. The same feature was also introduced in the stable firmware release 4.7.1.
The reason for a revision is due to a change in chip suppliers, however, there is no difference in performance between existing and upcoming hardware revisions.
Download link;
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v5.0.0-alpha4
How to flash the firmware;
help.prusa3d.com/article/flashing-firmware-mk4_453086
Please report any bug here:
Shane (AKA FromPrusa)
Publié : 18/07/2023 12:15 pm
Paul Harbin
(@paul-harbin)
RE: 5.0.0-alpha4 Firmware for Original Prusa MK4
So ... 10 hours into an input shaping test print. I turned my pc back on, which was still connected to the Type -C and the printer resets.  Fun times. Can we turn that off next go around?
Publié : 25/07/2023 6:08 am
3DesignsCH
(@3designsch)
You should avoid connecting V+ when connecting a PC to the USB port - it won't happen 🙂
Publié : 25/07/2023 10:59 am
Jakub Dolezal
(@jakub-dolezal)
Membre Admin
Hi Paul, thanks for the report. I will talk to the devs.
Assembly manuals
/ Knowledge Base
Publié : 25/07/2023 12:22 pm
Paul Harbin
(@paul-harbin)
I only plug in where I can reach =)
Posted by: @3designsch
Publié : 25/07/2023 12:26 pm
Oaradla
(@oaradla)
Membre
I have tested vase mode with IS but it doesn't print spirals, you can see a clear nat and the indents. The same model printed with 4.7.2 results as expected.
Publié : 11/08/2023 5:52 am
Jakub Dolezal
(@jakub-dolezal)
Membre Admin
Hi guys,
a new version, was just released! Read about the release candidate 5.0.0-RC here: https://forum.prusa3d.com/forum/input-shaping/5-0-0-rc-firmware-for-original-prusa-mk4/
Assembly manuals
/ Knowledge Base
Publié : 12/08/2023 1:57 pm
1 personnes ont aimé
