Input shaper on Tool 1 only issues.
Andrew Lochow
(@andrew-lochow)
On larger prints, Tool one only has a ton of small layer shifting. Tested this on 6.2.4 and 6.2.5 firmware. Haven't reverted to 6.1.3 to test this there, but anything on tool 1 usually looks like this. 6.2.4 was working fine for awhile. But I am suspecting something other than input shaping or temperature warping. The printer was running great until about a week ago. This issue only seems to be affecting tool one. Other tools seem just fine. Only thing different about tool 1 is that it has a diamondback nozzle on it for abrasive materials. Again, it was running great until about a week ago. Here is what I have tried so far:
  • Running in Stealth mode to reduce acceleration
  • Recalibrated tool heads
  • Recalibrated all Axes
  • Checked for obstructions and loose parts on and around Tool 1
  • Checked for detritus everywhere on printer, The printer is clean.
  • Filament is dry
  • Belts are tensioned to exactly 80hz each
This topic was modified 10 months ago 2 times by Andrew Lochow
Posted : 02/05/2025 9:51 pm
senatorpjt
(@senatorpjt)
RE: Input shaper on Tool 1 only issues.
I have been using Overture PETG with the default PETG profile, except with the extrusion multiplier turned down to 0.96. I was getting layer shifts and crashes with the default profile due to material accumulating on the nozzle and leaving blobs.
Posted : 24/06/2025 1:19 am
