Organic supports w/ Input Shaper extremely difficult to remove
I switched to input shaper a few days ago. I've got some parts that I print for an assembly of stuff that I've done dozens and dozens of times. Normally the organic supports pop off no problem (previous 0.20 Quality and 0.25 Draft), but since switching to input shaper they've become almost impossible to remove without cosmetic damage. I'm using the "0.15mm Speed" profile. For the supports I'm using organic with various combinations of:
- top contact: 0.17, 0.2mm
- Top interface layers: 0, 3, 4
- Pattern spacing: 2mm, 3mm
- XY separation: 75%, 80%
Nothing is materially changing the outcome.
The time savings would be _superb_ on some of the larger parts but I'm not sure what settings to modify at this point.
Opublikowany : 16/10/2023 7:33 pm
RE: Organic supports w/ Input Shaper extremely difficult to remove
What are your organic support settings?
Opublikowany : 06/11/2023 11:36 pm
