Massive Under Extrusion in Corners - Mini with IS
Colton Campbell
(@colton-campbell)
I have seen a couple other posts about this, but no answers/solutions.
I get massive under extrusion just on the corners of my prints when using input shaper. This occurs with PLA and PETG (I tested both on the same part). I have seen other threads about underextrusion at seams etc, but this is much more prominent than that issue (and potential bowden tube related issues).
Does anyone know how to solve this problem? Is it a slicer issue or a printer issue?
Best Answer by Colton Campbell:
I did some tinkering with the pressure advance settings and that pretty much solved the above issue with input shaper. I had to lower the "S" value from about 0.25 to about 0.11.
Now I just need to fix a final issue with the seam having small gaps in input shaper mode.
Posted : 16/10/2025 4:22 am
_KaszpiR_
(@_kaszpir_)
RE: Massive Under Extrusion in Corners - Mini with IS
first look at https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/how-often-to-replace-various-parts-on-the-mini-a-proposed-regular-part-replacement-schedule/ and do general maintenance.
If that does not help please provide more details about firmware, prusa slicer version, profiles and example model - there's just too many factors that thighs can go wrong.
Posted : 16/10/2025 11:02 pm
Colton Campbell
(@colton-campbell)
Posted : 17/10/2025 4:12 am
