First print with input shaper
G Bell
(@g-bell)
All worked well and print time went from 3.5 hours to 2.5 hours.
Only strange thing was that the nozzle temperature for "Generic PLA" was set to 230/220, which is very high.  Perhaps this is a change in PrusaSlicer?  Since I upgraded to 2.7.0 if I select "Generic PLA" the filament temp is 215/210 using an MK3S profile (as expected) but 230/220 if I am using the "Prusa Mini+ Input Shaper " profile??
Napsal : 25/11/2023 12:32 am
RE: First print with input shaper
Input shaper profiles have higher temperatures so filament can be pushed through the hotend faster.
Napsal : 25/11/2023 7:56 pm
1 lidem se líbí
_KaszpiR_
(@_kaszpir_)
Faster prints require higher temperatures because filament takes heat away when is extruded, so normal temps would be just too low for proper flow and could produce gaps in prints.
Napsal : 25/11/2023 9:41 pm
1 lidem se líbí
G Bell
(@g-bell)
Thanks, makes sense.  I manually lowered the temp to 215 and it seemed OK, but good to know.
Napsal : 25/11/2023 10:07 pm
