Error during printing - precise_stepping.cp
SnyderLV
(@snyderlv)
Miembro
I am having occasional print errors while using the new 5.1.0-alpha1 Firmware on a Mini+.  I am attempting to print using a .25 nozzle.  I have had this issue occur with two different g code files.  The occurrence with this print has happened twice at around the same point in the print.  I have included pictures of the stopping point of the printer in mid-extrusion as well as the blue screen error code precise_stepping.cp.  In addition, I have included a zip containing the gcode file for this print as well as the dump_buddy.bin file generated from the crash.
I had this same error happen two times on another gcode, but they did not occur at the same point in that print, one was toward the beginning of the print and the second was near the end of the print.
Torrga Brawnanvil_0.25n_0.05mm_PLA_MINI_5h19m
Respondido : 05/10/2023 8:14 pm
The code *is* in alpha so a few errors are to be expected.  report this, with all the settings and files used, on Prusa's github and the devs will take a look at it.
Respondido : 06/10/2023 12:36 am
