Does it affect modified Mini+ with Direct Drive?
Stránka 1 / 2
Madcamper
(@madcamper)
As the title states, how does the new input shaper firmware for the mini+ affect those with a direct drive upgrade or does it? Specifically the sherpa mini. Has anyone tested it yet? I also have a revo mini but have read that most with this upgrade have not seen any negative impacts.
Napsal : 20/09/2023 1:16 pm
huskyte
(@huskyte)
RE: Does it affect modified Mini+ with Direct Drive?
As an unproffesional reply I had a look at the IS values (currently alpha). Coming from a sppenmonster in the form of a RatRig 200 AWD 48V I still find the x values of the Mini... obscene? I cannot think a way to even run into the IS short of using the x gantry as linear rail gun. 132 Hz would come into effect around 50 k acc? So, I guess, even with PrusaSlicers alpha Mini profile you won´t run into issues.
As for y... no effect here for sure, with thirtyish MZV not a bringer, but not reachable anyway with a bed pusher
Napsal : 20/09/2023 3:52 pm
1 lidem se líbí
prodat
(@prodat)
I run it since yesterday on a Prusa mini with direct drive.  I only change my values for retract distance and retract speed and thats all. The steps for extruder are already changed in the hidden option from the prusa mini.
The prints are 40% faster and looks very great.
Napsal : 20/09/2023 6:00 pm
1 lidem se líbí
Cipis
(@cipis)
You certainly cannot use stock pressure advance values.
Napsal : 21/09/2023 8:16 am
singlefin
(@singlefin)
Will these settings translate over to Mini upgraded to Bear with Mk3 extruder?
Posted by: @podat
Yes thats correct, I take the values from the MK4 with pressure advance.
Standart value was M572 S0.3 (Mini with Bowden extruder and 0.4mm) and I changed to M572 S0.038 ( MK4 with direct extruder and 0.4mm nozzel)
Napsal : 22/09/2023 10:02 am
prodat
(@prodat)
Yes I think so, if you have a 0.4mm nozzel
Napsal : 22/09/2023 11:08 am
kolba
(@kolba)
Seems to work pretty good with default SPEED profile (140mm/s) and baked IS values on my direct drive mini with IGUS rods and bearings upgrade.
Had to remove any LA commands from filament profiles and slightly tweak the printer profile gcode to match my steps. With a quick PLA@225c and 140mm/s test the pressure advance value seem to be around 0.01. maybe 0.02 for petg?
Napsal : 23/09/2023 11:38 am
rinkel
(@rinkel)
How did you set Pressure Advance?
Pressure Advance: M572 Sxxx.xxxx
Linear Advance: M900 Kx.xxx
I tried turning off Linear Advance and only use Pressure Advance (setting from MK4), but that did not work nicely.
Posted by: @kolba
Napsal : 02/10/2023 12:32 pm
rinkel
(@rinkel)
Ok, i found this in the MK4 filament gcode:
M900 K{if nozzle_diameter[0]==0.4}0.05
{elsif nozzle_diameter[0]==0.25}0.14
{elsif nozzle_diameter[0]==0.3}0.07
{elsif nozzle_diameter[0]==0.35}0.06
{elsif nozzle_diameter[0]==0.6}0.03
{elsif nozzle_diameter[0]==0.5}0.035
{elsif nozzle_diameter[0]==0.8}0.015
{else}0{endif} ; Filament gcode
M572 S{if nozzle_diameter[0]==0.4}0.038{
elsif nozzle_diameter[0]==0.5}0.025
{elsif nozzle_diameter[0]==0.6}0.02
{elsif nozzle_diameter[0]==0.8}0.014
{elsif nozzle_diameter[0]==0.25}0.12
{elsif nozzle_diameter[0]==0.3}0.08
{else}0
This means still LA for 0.4 nozzle on MK4, but not on the Mini
Unfortunately this did not work for my Mini Bear
I'll try to modify the Ellis test for Pressure Advance instead of Linear Advance
Napsal : 02/10/2023 12:43 pm
kolba
(@kolba)
are you using new printer profiles? that is baked into printer and filament profiles. though values are tuned for bowden, so would need changing.
Napsal : 02/10/2023 12:48 pm
rinkel
(@rinkel)
Yes, i just saw.
I now turned off LA and using PA only.
I accidently added the gcode to the printer setting
Working fine now, better than LA !
Napsal : 02/10/2023 1:45 pm
singlefin
(@singlefin)
How did you turn off LA? Comment out the M900 commands?  Do you mind sharing your PA settings for your Mini Bear?  Thank you!
Posted by: @rinkel
Yes, i just saw.
Napsal : 02/10/2023 4:23 pm
rinkel
(@rinkel)
LA is always set in filament gcode.
Remove everything there and set:
M900 K0 ;Disable Linear Advance
M572 S0.038 ;Set Pressure Advance. This value is for Mk4 DirectDrive extruder
Napsal : 02/10/2023 5:20 pm
singlefin
(@singlefin)
Thank you!  By the way which configuration preset did you use in Prusa Slicer, the Mini or the Mk4 ?
Posted by: @rinkel
Napsal : 02/10/2023 5:36 pm
Cipis
(@cipis)
You don't have to disable LA by M900 K0 command. Just use M572 S alone.
Also (side note), the firmware automatically converts "M900 K" commands to M572 S.
Napsal : 02/10/2023 6:28 pm
rinkel
(@rinkel)
Any idea how that conversion works?
What would be the M572 equivalent for M900 K0.03 ?
Because i know my LA, but not my PA.
Best for me would be to stick with my LA then...
Napsal : 02/10/2023 7:08 pm
rinkel
(@rinkel)
After taking a better look, the values are quite close, seems PA is a bit lower.
I could use the ellis test with an M572 instead of M900. Should work.
Napsal : 02/10/2023 7:51 pm
kolba
(@kolba)
Yeah, for your M900 K0.03 you would probably go 0.01 or 0.005 for PA.
I was a bit surprised to hear that apparently firmware would convert M900 commands to M572. sorta handy in theory but probably a recipe for disaster in practice
Posted by: @rinkel
This post was modified před 2 years by kolba
Napsal : 03/10/2023 10:21 am
Madcamper
(@madcamper)
I may have missed it in the previous posts, but I just updated to the new firmware on the mini+ and while I'm able to print, they don't look as good as they did prior to input shaper. It appears I'm getting under extrusion on some corners and seams, also supports. I'm still using a revo micro and a sherpa DD. The Custom GCode for my filament settings is "M900 K0.05 ; Filament gcode" and only thing I've added to the default Input Shaper printer profile is my PID settings and the below.
M603 L80 U80 ;set the load/unload filament length
M906 T0 E600 ;set current for the extruder motor
Aside from that, all the other profile settings are default. Any ideas what I should change?
Napsal : 28/11/2023 12:00 am
Madcamper
(@madcamper)
Here are pics of what I am referring to. Prior to input shaper, this was not a problem. The straight line on the inside is the seam.
Napsal : 28/11/2023 1:57 pm
Stránka 1 / 2
