Custom G-Code M593
Pran
 Pran
(@pran)
Custom G-Code M593
Hey there, I've just printed the ringing tower of the Klipper documentation and noticed a little ringing. Then I wanted to fine tune it so I just written the command
M593 X T2 F77.8
M593 Y T2 F146.6
Right above the intro line comment of my start G-Code.
My problem is that the printer still shows the default parameters if I go to the settings while the print is running and the results still more or less the same, so they dont seem to apply.
Could anyone tell me what I did wrong?
Opublikowany : 08/10/2023 4:32 pm
rinkel
(@rinkel)
RE: Custom G-Code M593
Same here. When turning off input shaper ringing appears, so it is working. Changing the values however don't seem to make much of a difference in the ringing tower.
I modded my Mini to a Bear with direct drive, so my settings are way off.
Opublikowany : 09/10/2023 6:18 am
PrusaTester2020
(@prusatester2020)
Is there any change in Alpha-2 firmware and how are we suppose to fine-tune the input shaper if the M593 command is not working?
This post was modified 3 years temu by PrusaTester2020
Opublikowany : 14/11/2023 6:49 am
