Cannot link Mini+ to Prusa Connect
astrophage
(@astrophage)
When I attempt to connect to Prusa Connect on my Mini+ I get the following error message:
Registration to Prusa Connect Failed.
More details at help.prusa3d.com/connect_error
However, the URL help.prusa3d.com/connect_error goes to a 404 error. Has anyone gotten their Mini connected to Prusa Connect?
Prusa Link: Working
Prusa Connect: Not Working
Dieses Thema wurde geändert Vor 3 years von astrophage
Veröffentlicht : 20/09/2023 9:05 pm
blackRhino
(@blackrhino)
RE: Cannot link Mini+ to Prusa Connect
Im in the same boat. Got onto chat support with Prusa, but wasn't able to solve it for me. Did a hard reset, re-flashed 5.1.0, re-connected wifi module, connected to link successfully. Still got that same screen above.
Veröffentlicht : 20/09/2023 9:24 pm
blackRhino
(@blackrhino)
They did have me load this setting via an ini file:
[service::connect]
hostname = buddy-a.connect.prusa3d.com
tls = True
port = 443
into the "Load Settings" area, which at first seemed like it did something good because it went to a screen that looks like this:
However, nothing changed
Veröffentlicht : 20/09/2023 9:33 pm
Hello
(@hello)
Posted by: @astrophage
Prusa Link: Working
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3133
That's the xl I know but it's the same problem
Adding the dumbby code should have started it correctly what do you mean nothing changed will it just not connect
Posted by: @blackrhino
[service::connect]
tls = True
port = 443
Veröffentlicht : 20/09/2023 10:06 pm
kspear
(@kspear)
Mitglied
+1
Veröffentlicht : 20/09/2023 11:03 pm
blackRhino
(@blackrhino)
After it shows that "Loaded Successfully" screen it never activates as far as I can tell. The status remains "No config"
When I select "Add printer to connect" the registration always fails like in the first post.
I went to the github bug link, and tried that specific code, but didn't work either
Veröffentlicht : 20/09/2023 11:10 pm
bg1627
(@bg1627)
Same issue here.  I kept trying the "Add to Connect" option and eventually instead of failing it actually went through gave a code, but it still shows as "no config" in the settings.  It's registered online, but shows as "offline."
Veröffentlicht : 23/09/2023 12:47 am
NightlyH
(@nightlyh)
Mitglied
I too cannot get this to work. Probably just alpha firmware being alpha. I''m sure this will be fixed soon enough.
Veröffentlicht : 23/09/2023 4:08 am
Dan
 Dan
(@dan-7)
Mitglied
I got the same error initially but then I turned off prusa link before trying to enable prusa connect and it worked for me!
Veröffentlicht : 23/09/2023 7:29 pm
PaulBGD
(@paulbgd)
Mitglied
That almost works for me, but now it's stuck in a loop of trying to connect and failing. Here's my process, maybe someone else can get further:
  1. I enabled prusa link, which works
  2. Per Dan's comment above I disabled it, which after restarting the printer I was able to get a registration code for connect
  3. Adding the printer worked, but the printer shows perpetually offline in connect. On the printer's side it still doesn't think it's setup to connect.
  4. I go into settings in prusa connect and download the .ini file to the flash drive, then load the settings from it to the printer
  5. Now it loops between "Connecting" <-> "net fail"
Veröffentlicht : 26/09/2023 7:45 pm
blackRhino
(@blackrhino)
I did a factory reset (settings only) of my mini, and that got it working. One thing I did though is once I got the code on my printer and entered it into connect online it said my printer was offline. I went to the settings in connect online & downloaded the LAN file. I removed everything in the file except for the [service::connect] section. You should see your token at the bottom of it. Then load it into the connect settings in the printer, and it began to work for me. I also had to turn off Link for it to be consistent.
Diese r Beitrag wurde geändert Vor 3 years 2 mal von blackRhino
Veröffentlicht : 28/09/2023 6:43 pm
Busy With 3D Printing
(@busy-with-3d-printing)
I am also having problems with PrusaConnect on the Mini. I can get it to work for a few hours, and then it never works, so I remove it from my account and try to set it up again. And it fails for a long time, and then finally it works, and the cycle goes on. As you see, this is not one bit convenient. Tho...
Posted by: @nightlyh
Veröffentlicht : 01/10/2023 11:32 pm
Another thing I noticed...
You can't send files from PrusaSlicer to PrusaConnect in PrusaSlicer.
Veröffentlicht : 02/10/2023 12:04 am
blackRhino
(@blackrhino)
As I posted above, I have been able to get connect working. Though I am also experiencing the printer intermittently getting disconnected from connect. It happens regularly during the day. Usually right after I start a print, and a few times during the middle of the print.
Veröffentlicht : 02/10/2023 4:28 pm
blackRhino
(@blackrhino)
I am also missing the option to send files directly from prusa slicer to connect
Veröffentlicht : 03/10/2023 3:23 am
HainjeDAF
(@hainjedaf)
I finally reset my connection.
I generated new passwords and API codes.
And then I bot in PrusaSlicer and in PrusaConnect re-registered my printer.
Now it works fine and I also can put files in subfolders. Something that firmware 4.4.1. doesn't do.
Veröffentlicht : 03/10/2023 10:43 am
Where is MINI?
Veröffentlicht : 04/10/2023 8:34 pm
blackRhino
(@blackrhino)
It seems they have fixed something. My mini has stayed connected all day today, which hasn't happened ever.
Veröffentlicht : 04/10/2023 9:22 pm
blackRhino
(@blackrhino)
Ugh never mind. Went offline again 🙁
Veröffentlicht : 04/10/2023 10:24 pm
