Z noise when starting print
When starting a print, my mini lowers to begin its bed mesh. When doing so a mmmmrrrrrrrrr sound. Does it need a lube? If so what kind / brand?IMG_1941smaller
Publié : 28/06/2020 4:27 pm
RE: Z noise when starting print
Take a look at this post. It might help you sort out the problem. I found that my problem was lying on the z rod lead screw. Do not lubricate the Z axis plastic block since Prusa states that this lead screw nut is self lubricating and it might do more harm than good.
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
Publié : 07/07/2020 5:54 am
2 personnes ont aimé
