What causes this:
Steve
(@steve-4)
What causes this:
Does anyone know what causes this, and how to stop it?
It's Matterhackers MHBuild PETG, and I'm using a slightly modified version of the generic PETC profile on Prusaslicer  with a .6mm nozzle..
Thanks
Senior Life member of IEEE.
Publié : 31/01/2022 11:27 pm
Steve
(@steve-4)
RE: What causes this:
Publié : 01/02/2022 12:45 am
Your first layer Z calibration is very low, so low that excess filament is squishing out to the side and then riding up against the adjacent strand.
Publié : 01/02/2022 12:50 am
Steve
(@steve-4)
I needed to set it low so that it would stick to the PEI sheet.  I cleaned the PEI sheet with dish soap and water, and dried it well.
Publié : 01/02/2022 1:00 am
I didn't say *too* low.  I suspect it could could come up a fraction but for now, whilst that sheet needs it, you should be OK just to continue...
Finish a print then show us the underside; does it look ugly?
Publié : 01/02/2022 5:21 am
Steve
(@steve-4)
I'm also getting blobs on the surface, so continuing the print won't work.  Also, I can't find thr extrusion multiplier in the new Priusaslicer.
Publié : 01/02/2022 1:15 pm
Thejiral
(@thejiral)
Is your filament dry? Wet filament can lead to artifacts on the side walls. (Check for occasional vapor or hissing at the nozzle when extruding filament) It could possibly also be slicer settings, that infill speed is maybe too fast and perimeters too few.
How old is your PEI sheet? They don't get better over time if heavily used. One more thing. if you are printing such a large object in PETG, you may want to print with brim. Adhesion can be generally be an issue with large objects if your sheet is not in stellar condition.
Publié : 01/02/2022 2:51 pm
What colour blobs?
Filament Settings > Filament >
Publié : 01/02/2022 3:52 pm
Steve
(@steve-4)
Mostly white, with a few black spots.  The filament is white PETG.
Publié : 01/02/2022 5:37 pm
Steve
(@steve-4)
The PEI sheet is brand new.  I cleaned it with dish soap, dried it, and then cleaned it with denatured alcohol.  I had to reset the z calibration when I got the new sheet, but I believe this is because the tolerances of the actual sheet.  I printed one part fine, then I got an enclosure and this started happening.
Publié : 01/02/2022 6:32 pm
Examine you nozzle/heater block assembly - is there filament trickling down from above?  The black spots make me wonder if the nozzle is seated correctly.
Publié : 02/02/2022 1:22 am
Steve
(@steve-4)
Nozzle is seated correctly.  It was printing fine until I got an enclosure for the printer.  Now it's printing like this.  I typically change nozzles for different parts, and am careful to screw the in correctly.  In this case, it is a .6mm nozzle.
Looks to me like it is over extruding.
Publié : 02/02/2022 1:36 am
You don't need an enclosure for PETG.  Try without, it may be amplifying your problems.
Publié : 02/02/2022 9:56 am
Steve
(@steve-4)
In my case, the object I was printing just barely fit on the build plate and I was getting warping in the ends of the object.  That's why I went with an enclosure.  I normally print PETG without an enclosure.
I am usung the small Creality enclosure.  Printer fits fine.  Easier than building one myself.
https://www.creality.com/goods-detail/creality-3d-printer-enclosure.
However, I would still like to know what my problem is.  I don't want to waste filament if someone knows what causes the problem.
I have had too small a Z axis lift before, and never got this.
Bad filament?  Over extruding?  They hid the extrusion multiplier in Prusaslicer 2.4.  Anyone know where it is?
Publié : 02/02/2022 11:28 am
Membre
Probably not a bad filament.  Did you try a different filament?  It could be wet (hydrated).
Publié : 02/02/2022 11:36 am
Steve
(@steve-4)
Don't have another white filament.  Filament is dry-Dried it.
Publié : 02/02/2022 7:39 pm
