Uneven top layer
matus141
(@matus141)
Uneven top layer
Hello guys, i noticed my latest prints have uneven top layers as shown in the picture. I have this problem with generic PETG and prusament PLA, both look the same. Can you guide me how to solve this problem? thank you
Opublikowany : 26/08/2021 9:34 am
do you have enough top layers to mask the infill?
this looks like slight over extrusion
try reducing your flow rate, a little
Prusa slicer normally sets the flow rate at 95%, try 90%
Opublikowany : 26/08/2021 11:24 am
matus141
(@matus141)
thank you, i will try this... but for me it looks like underextrusion? I am fine with the filled areas, i dont like the ones where lines dont touch each other. i have 4 top layers.
Opublikowany : 26/08/2021 12:57 pm
Ploughing
Hi Matus,
I am hundreds of miles away...  lol..   to me, it looks like the nozzle is pushing some material out of the way, as it moves across the surface.
And I think that is causing the ridges where the surface is rough!
you are able to touch the surface, are the rough parts raised?
Opublikowany : 26/08/2021 1:07 pm
matus141
(@matus141)
RE: Uneven top layer
from left to right 100%, 95%, 90% flow rate... didnt work 🙁
This post was modified 5 years temu by matus141
Opublikowany : 26/08/2021 4:17 pm
Can you export the project (Save Project As in PrusaSlicer) as a 3mf file, ZIP it (important), and upload it so we can see the model and all your settings?
Opublikowany : 29/08/2021 2:07 pm
