Uneven Layers with "cracks"
Harakiri
(@harakiri)
Hi there,
as you might've already seen on this picture - there are some kind of holes or cracks on the layers of this print (best visible on the longest part). Do you know how to avoid it? At first I thought it's the seam but it's not.
Thanks a lot in advance!
Dieses Thema wurde geändert Vor 5 years 2 mal von Harakiri
Veröffentlicht : 23/02/2021 10:43 am
RE: Uneven Layers with "cracks"
Were there any popping sounds during the print?
Is it possible your filament is damp?
Veröffentlicht : 23/02/2021 11:10 am
Harakiri
(@harakiri)
No popping sounds, more like crackling sizzling sounds. But I do have those sounds even with completely new filament / prusament.
Veröffentlicht : 23/02/2021 11:39 am
OK. If the filament is damp, water boils off in tiny explosions which can cause fluctuations in the printing pressure. "crackling sizzling sounds" might indicate that process.
Look for threads on here about drying filament.  Try to get enough filament thoroughly dry to do a test print.
Hth, Cheerio,
Veröffentlicht : 23/02/2021 3:49 pm
Harakiri
(@harakiri)
Thanks so far for your help! Unfortunately I do not think that this is the case, because it happens with freshly unpacked prusament too - which should be dry, right?
Veröffentlicht : 23/02/2021 7:11 pm
towlerg
(@towlerg)
"which should be dry, right?" The emphasis here is on should. If you're hearing a crackling fizzing sound, the most likely cause is wet filament.
Veröffentlicht : 24/02/2021 12:19 pm
