Underextrusion thin columns
4m1r
 4m1r
(@4m1r)
anybody know why i get underextrusion toward the top of this model, but the rest is great?
Opublikowany : 12/08/2021 4:56 am
ideas
Have you tired more than 1 filament?  Can you post your zipped 3MF file so we can look at it?
Opublikowany : 12/08/2021 9:49 am
4m1r
 4m1r
(@4m1r)
No 3MF file here
Thanks Chuck, I only have the STL, not sure how to export 3MF, and the GCode is apparently too big to attach here?  14.7MB.  This seems to be a problem for me whenever I have any thin, tall columnar prints.   But something like a hole in the middle of a thick bit of material seems almost perfect, so I'm wondering if its related to speed or cooling?
Opublikowany : 19/08/2021 3:41 am
BogdanH
(@bogdanh)
how to get 3mf file
When you import stl file into PrusaSlicer and after you make adjustments, do "File -> Save Project as.." -that will create 3mf file. Zip that file and attach it here.
[Mini+] [MK3S+BEAR]
Opublikowany : 19/08/2021 8:02 am
RE: Help
This might help:
Click on the image to have a visual map:
Opublikowany : 19/08/2021 9:54 am
4m1r
 4m1r
(@4m1r)
RE: Attached 3MF file
Got it, thanks guys.  So what do you look for in the 3MF?
Attachment removed
This post was modified 5 years temu by 4m1r
Opublikowany : 20/08/2021 4:08 am
Print 3MF
Posted by: @4m1r
Attachment removed
I look at your settings.  I will look at the layers in the slicer.  I may even test print it.
Opublikowany : 20/08/2021 10:49 am
tonight - timed out
I will look at it after work if none of the wizards of the forum beat me to a solution.
Opublikowany : 20/08/2021 10:51 am
Some thoughts about your settings:
You have only two perimeters, for a functional object that may be subjected to variable loads this may be rather fragile, I suggest three or even four would be better.
For the same reason, enable 'Extra perimeters if needed.'
Your temperatures are practical, the 'Other layers' value could go lower safely but it's not essential.
...but I cannot see anything that would cause the failure you experienced.
The problem seems to have arisen at about the time the printer would have begun slowing to allow the very small amount of extrusion on each diminishing layer to cool.  If there was a partial clog this might have magnified the impact.
There is a little bit of what looks like bubbling and light stringing ... I have seen this when a damp filament has been oven dried for too short a time, the outer layers dried and print well but underlying layers remain damp..?
I would try a cold pull in case there is a partial clog, increase the perimeters and try again with a known dry filament.
Opublikowany : 21/08/2021 7:40 am
4m1r
 4m1r
(@4m1r)
Added the extra perimeters
Thanks guys, I've added the following quality settings and just printed another print (albeit not as overrhang heavy) and seems to be fine. I'll have to try a very specific test ( i don't want to print the damn headphone thing again. 😉 ) But I think you're right, additional perimeters should help.  I'll update the thread after next column print.
Opublikowany : 24/08/2021 8:09 pm
