Trying to print part with moving sections.
Craig
(@craig-3)
I am trying to print a PCB vise from Thingiverse - somewhat to learn more about printing models with motion. The model has a base plate, skips two layers, and then prints zig-zag shaped springs and jaws. I had a lot of filament pulling when the spring shapes restarted although there was also significant adhesion between the parts that I was able to seperate with a putty knife. I used Prusament PLA filament and then default slicer settings for this material.
I have never tweaked print parameters before and I am looking for suggestions about where to start. Hotter or cooler temps on both bed or extruder, skip 1 or 3 layers, thinner or thicker layers? One user in the comments had adjusted printer speed. Can I slow the speed down for 1 or 2 layers in the Slicer?
Any comment or feedback would be greatly appreciated. As I said, this is a learning part to try single piece moving prints.
TIA.
Veröffentlicht : 17/08/2020 8:52 pm
jsw
 jsw
(@jsw)
RE: Trying to print part with moving sections.
Do you use supports for the bottom of the springs?
Veröffentlicht : 17/08/2020 9:04 pm
Craig
(@craig-3)
I had thought of supports, but they would be almost impossible to remove in the corners of the springs.
Veröffentlicht : 17/08/2020 9:19 pm
John
 John
(@john-6)
I would reconsider the supports. If you adjust the support settings so the interface layer is, say 5 or more mm you might find that the support will break away with movement of the bellows.
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Veröffentlicht : 17/08/2020 10:40 pm
jsw
 jsw
(@jsw)
Posted by: @puetz
Did you use the default support parameters or adjust them.  The ones that have been cited on the forum for good break-away supports are:
0.25mm z distance.
75% xy distance.
3mm support spacing.
4 interface layers.
0.2mm interface layer spacing.
Veröffentlicht : 17/08/2020 10:42 pm
Craig
(@craig-3)
Thanks. I will investigate that idea.
Veröffentlicht : 18/08/2020 1:01 am
Gordon W
(@gordon-w)
This video, about this design, or one very similar, might be helpful
Veröffentlicht : 18/08/2020 2:42 pm
Craig
(@craig-3)
@gordon-w
Actually, that video is where I started. I like the idea so I downloaded the file from Thingiverse and started. I mostly used the stock Prusa settings for my Mini and Prusament PLA. In the video, his layer thickness was 0.28 on his Ender. I left the my layer setting at the stock 0.15. I recognized that I might have more adhesion, but in fact my issue was too little adhesion across the gap so I would expect that increasing layer thickness would hurt, not help. On the other hand, the thicker layer would lay down a larger string of material so it might stay in place better. That's a point I hadn't thought of until now, so if anyone has experience please chime in. As I said, this is primarily intended as a learning piece, so I may give thicker layers a try after I play with supports.
BTW, the designer replied to me on Thingiverse that he wasn't aware of others having the issue I had (I posted there as well).
Does anyone have comments about temps? Again, I left my settings at the Prusa recommendation for their material - 215 extruder and 60 bed.
Thanks again for the responses.
Veröffentlicht : 18/08/2020 5:54 pm
kimwo
(@kimwo)
@puetz
I have just had a go at this using the ideas of @jsw for support.  This is it straight after printing (sorry about the brown filament!):
The changed settings for the mini were 1) layer height 0.3mm and 0.35mm - only because it speeds it up by 3 hours.  I do then slow down to 90% speed and 90% flow factor using the manual settings (the flow factor has to be set just before printing starts or the program overwrites with its own setting of 95%).   When slicing I couldn't use the 0.25mm  Z  distance because the support material was everywhere except under the spring! So I put it back to the default 0.1mm.  I also changed the interface pattern spacing to 0.4mm (from 0.2mm).  This had the effect of thinning out the support so there was less to remove - it pinged off with tweezers.  I think I got it all out from under the springs.
When I did the slicing, initially I had automatic support on - but this created all sorts of unneeded support round the edge.  So I unclicked "autogenerated support" and clicked on "generate support material" and then right clicked on the model to add a support enforcer box.   As shown below:
If I were to do it again I would try and go right to the hinge points.  That gave me a support pattern like this:
Although this generates all sorts of unnecessary support around the vice faces,  I found it easily separated and pulled out with tweezers.
Only one problem - I was a bit rough with the end of the push rod and the bit where you put your finger broke - so I have glued it - wrong to use only 15% infill default I think.
There you go - a nice project to expand my newbie skills - and useful.
Veröffentlicht : 18/08/2020 7:55 pm
Gordon W
(@gordon-w)
@puetz
😀 I too saw the video and downloaded the model, but haven't got round to printing it yet, so watching this thread with interest. It looks like @kim-1 has found a good support configuration so there is hope!
Veröffentlicht : 19/08/2020 8:28 am
bobc
 bobc
(@bobc)
I guess it is fun to pull a print off and have it work straightaway, but it seems like this model would be a lot better printed in two parts. If you have to fiddle around removing support, gluing a couple of parts together instead seems like a good trade-off.
Veröffentlicht : 19/08/2020 10:28 am
Craig
(@craig-3)
Hey everyone - thanks a million for the helpful suggestions. I applied supports with an enforcer box, parameters adjusted per the above recommendations. It printed very nicely, with just a couple of rough corners. It took some scraping, but all of the supports came off nicely.
Goals achieved - I dug more deeply into PrusaSlicer, learned a lot, and have a handy gadget.
Veröffentlicht : 20/08/2020 11:32 pm
jsw
 jsw
(@jsw)
Very nice.  Congratulations.
Veröffentlicht : 20/08/2020 11:35 pm
