Trouble printing flat object
caddygolf
(@caddygolf)
Hello,
Trying to print the object in the image. It appears flat, but get an error and test print one side was not flat on the bed. Any tips on how to fix this would be appreciated.
Opublikowany : 08/12/2022 2:30 pm
If the bottom surface is actually flat and the model is just tilted , you can press the F key and select the bottom to place it on the printbed.
If it's not flat, you need to fix it in your design software. Or if it's a minor tilt, you can use the cut tool (C) to cut away some of the bottom surface, to straighten it out.
Opublikowany : 08/12/2022 2:58 pm
2 ludzie polubili
