If the bottom surface is actually flat and the model is just tilted , you can press the F key and select the bottom to place it on the printbed.
If it's not flat, you need to fix it in your design software. Or if it's a minor tilt, you can use the cut tool (C) to cut away some of the bottom surface, to straighten it out.
Respondido : 08/12/2022 2:58 pm
2 les gusta
