Top layer gaps - Images
Steverd
(@steverd)
I am getting these gaps/holes on a few tops layers on my Mini. This is rainbow filament by TTYT3D.
This is the articulated Slug file, sliced in PrusaSlice .20 quality default settings.
Is the solution the Minimum Shell Thickness TOP?
Default settings are:
Solid Layers Top 6, Bottom 4
Min, Shell Thickness: Top 0.7mm, Bottom 0.5mm
Thank you
Opublikowany : 04/12/2021 9:21 pm
