smooth bottom layer
Mcdriver
(@mcdriver)
smooth bottom layer
Is there a way to make all sides of a print smooth?
you don't know what you don't know, neither do I
Opublikowany : 16/12/2020 10:26 pm
mrstoned
(@mrstoned)
RE: smooth bottom layer
You will always get layerlines, they can be post-processed with primer/filler spray or spackel and sanding after.
Another option is to use ABS for example and use vaporsmooth or the polysmooth filament.
Search youtube for many examples and results.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
Opublikowany : 17/12/2020 10:40 pm
1 ludzie polubili
Rainer
(@rainer-2)
Prusa Slicer 2.3 RC2 with Ironing Feature 😉
Opublikowany : 25/12/2020 9:47 pm
