Prusaslicer question
Hi Guys,
Still a newbie so learning all the time.
I have a question about Prucaslicer, specifically 'support enforcers'
I know to right click on the object and then to select the 'enforcer shape' cylinder, block, slab etc
Is there a way to select a 'ring' or 'hoop' rather than a cylinder ??
I only want to enforce supports on the outer edge of a round object
Cheers
S
Opublikowany : 25/02/2020 1:19 pm
RE: Prusaslicer question
You can "Load..." an enforcer/blocker/modifier from your drive.
Opublikowany : 25/02/2020 1:56 pm
In other words, you can design the shape you want using your favourite cad package, eg Fusion360, save it as an stl, then Load it as the modifier shape.
Texy
Opublikowany : 25/02/2020 2:38 pm
1 ludzie polubili
Topic starter
answered:
Thanks guys that will help 👍
S
Opublikowany : 25/02/2020 2:51 pm
