Prusaslicer question
Sfbrain
(@sfbrain)
Hi Guys,
Still a newbie so learning all the time.
I have a question about Prucaslicer, specifically 'support enforcers'
I know to right click on the object and then to select the 'enforcer shape' cylinder, block, slab etc
Is there a way to select a 'ring' or 'hoop' rather than a cylinder ??
I only want to enforce supports on the outer edge of a round object
Cheers
S
Respondido : 25/02/2020 1:19 pm
Lichtjaeger
(@lichtjaeger)
RE: Prusaslicer question
You can "Load..." an enforcer/blocker/modifier from your drive.
Respondido : 25/02/2020 1:56 pm
Texy
 Texy
(@texy)
Posted by: @lichtjaeger
In other words, you can design the shape you want using your favourite cad package, eg Fusion360, save it as an stl, then Load it as the modifier shape.
Texy
Respondido : 25/02/2020 2:38 pm
1 les gusta
Sfbrain
(@sfbrain)
Thanks guys that will help 👍
S
Respondido : 25/02/2020 2:51 pm
