Prusa mini issue.
Redranger81
(@redranger81)
Prusa mini issue.
After several successful prints my mini has stopped printing. It will load, unload and purge the way it should but whenever I try to print I get something like this. I’ve tried several cold pulls and checked that the stepper motor is turning the pinion gear.
Opublikowany : 12/07/2021 3:45 pm
RE: Prusa mini issue.
Posted by: @redranger81
There may be an extruder blockage: https://help.prusa3d.com/en/article/clogged-nozzle-hotend-mini_112011
wbr,
Karl
Opublikowany : 12/07/2021 3:49 pm
Redranger81
(@redranger81)
@karl-herbert
Thanks. That’s good info on that idler screw.
Opublikowany : 12/07/2021 4:08 pm
Zoltan
(@zoltan)
Member Moderator
Does it work now?
@redranger81
does it work now?
Opublikowany : 18/07/2021 2:50 pm
Redranger81
(@redranger81)
It’s working again.
Yes. With some help from a friend and tech support we figured out that it needed a few cold pulls and redid the hot end to close up any voids.
Opublikowany : 18/07/2021 9:11 pm
Prusa mini issue
@redranger81
Thanks for the feedback. The simplest methods can often quickly result in success.
happy printing 👍
wbr,
Karl
Opublikowany : 19/07/2021 6:03 pm
