Problems with tall prints
I've been happily printing with my MINI for a year or two, but recently it has developed really odd issues with tall prints.
Most tallish (>1 inch) prints fail, with the print fading out in a way the looks like a clogged nozzle. However, if I remove the filament, clip off the ground down part and try again, it starts printing just fine, at least for the first inch or so. Some examples:
Short prints, even if they take a long time like this two hour plate of paracord winders are just fine.
Finally, I decided to a simple cylinder, which took and hour and finished but had terrible quality after about half an inch or so.
I don't think it's a clog, I've tried several cold pulls, cleaning filament and can get it to produce plenty of spaghetti without a problem. And I don't thing it's heat creep, because a long print that stays short also works great. Any ideas?
This is almost certain to be a first layer adhesion problem. There are hundreds of threads here about Z calibration and print sheet cleaning, go take a look.
It's definitely not first layer adhesion, the prints are rock solid on the sheet with a great looking first layer.
RE: Problems with tall prints
How ground down? May point to an issue with the tension on the idler screw. Why that would manifest only at certain Z heights, escapes me.
I would also check my filament path to make sure there are no obstructions that may happen as the x-axis moves up. If there's a kink in the Bowden tube or the feeder tube from the spool, it may impede the filament's ability to reach the nozzle.
Can you show us a picture of the whole printer as currently set up?
The Z axis doesn't usually suffer from loosened connectors or work hardened wiring failures but try moving from low to high Z (menu control) whilst lightly touching the carriage - does it move smoothly? If not, are snag points at predictable positions?
Looks like it was, in fact a heat creep/PTFE tube issue. I swapped it out and was very careful about keeping the tube pushed up while tightening the grub screws seems to have fixed it.
