Prints Caving Slightly after Adding Height Range Modifier
CalebLA
(@calebla)
Hi everyone!
I've been experiencing problems lately after adding a height-range modifier to my print.
The print is at 0.20mm except for when the height range modifier kicks in, going from 0.1-0.125-0.15-0.175-0.2mm (for a cleaner transition).
The only reason I am doing a height range modifier is that that part of the print needs structural stability, and 0.2mm wasn't giving me enough strength.
However, I started noticing that my print is sort of caving in where the height-range modifier is (shown below). The same object without height -range modifier is shown below for your reference.
Any thoughts on how to fix this? Help will be greatly appreciated!
Thank you,
Caleb
P.s - Using Atomic PLA for Yellow and Overture PLA for Black, Bed Temp 80c
Print With Height Range Modifier
Print Without Height Range Modifier
Posted : 17/11/2022 10:28 pm
Bob
 Bob
(@bob-2)
RE: Prints Caving Slightly after Adding Height Range Modifier
Pics aren't coming through.
Cheers
-Bob
Posted : 20/11/2022 8:38 pm
CalebLA
(@calebla)
Not sure why they are not coming through, but let me try a link to Google Photos:
For the print with height range modifier, click here.
For the print without the height range modifier, click here.
Hope this works!
Thanks
Caleb
Posted : 21/11/2022 2:32 am
mark
 mark
(@mark)
Why not include the pictures on the forum so they last as long as the forum is up? Links elsewhere invariably get lost in a few years.
Click the Add Media button, then Upload Files, select the image you want from your computer, then select Insert Into Post.
Regards,
Mark
Posted : 21/11/2022 2:50 am
CalebLA
(@calebla)
Great suggestion!
Print with height range modifier
Print without height range modifier
Thanks,
Caleb
Posted : 21/11/2022 3:05 am
