Printer doesn't print all of stl model
Hi, I've got a couple of MK3S+ printers, latest firmware and latest slicer and neither of them print this central part of the STL file - The whole entire arc block part.
So I end up with something like this, and then it's trying to print the center piece in the air when it gets to this height.
Here's the STL file.
http://199f0096ab9e839d49c4-f38e90dc860e94d93d82757ea3e76c3d.r69.cf2.rackcdn.com/docs/Solid3_2.stl
The STL file shows correctly in the Prusa Slicer, but just won't print the center piece.
Any help appreciated thanks
Opublikowany : 25/05/2022 2:39 am
The two parts are unconnected. Select 'Split to objects' then unclick the assembly and reposition the parts, they will both print on the bed.
Opublikowany : 25/05/2022 11:53 pm
Topic starter
answered:
RE: Printer doesn't print all of stl model
Thank you so much, I didn't even notice. I'll go back to my designer 🙂
Opublikowany : 26/05/2022 4:24 am
