Print head hight in move ?
Sfbrain
(@sfbrain)
Hi Guys,
I am having a little problem with one of my prints that has a tall 'support' structure under a dome.
During the print, as the nozel head moves accross the print to start its next deposit of plastic, it is catching the top of the supports.
Is there a setting that i can adjust to raise the print head, just a fraction when it is moving ??
Cheers
Steve
Publié : 18/11/2020 10:45 am
RE: Print head hight in move ?
Its called Lift Z in PS and is configured under the Printer profile in the extruder section.  I think the mini is configured to use a 0.2mm Lift Z by default.  Increase that to 0.3 or 0.4.  You don't want it to high as it does impact how long it takes to complete a print.
It can also be configured on a per filament basis by enabling it from the Filament Overrides page
Publié : 18/11/2020 12:56 pm
Sfbrain
(@sfbrain)
@neophyl
Thanks so much, will give it a try on the next print
Steve
Publié : 18/11/2020 12:58 pm
