RE: Print has jumped in X and Y axis?
The good old layer shift...
A whole bunch of reasons why it might happen:
- Pulley screws on X or Y motor not properly tightened. One has to be tightened against the flat side of the motor shaft!
- Belt not correctly tightened. Use this tension meter to get it right: https://www.prusaprinters.org/prints/46639
- X carriage over-squeezed. Loosen the back plate on the X carriage axis. (only relevant for Mk3S)
- Nozzle hit an obstacle. Some patterns such as grid have lines that cross within one layer. This can lead to little pile-ups at the intersection points, in particular if you have slight overextrusion, which in turn can lead to the nozzle catching at those pile-ups. See https://help.prusa3d.com/en/article/infill-patterns_177130/
- Zip ties on the wire bundle on the back of the extruder not properly positioned, so they or the cables hit the model.
Respondido : 12/10/2021 10:54 am
Topic starter
answered:
Reply
Thanks a lot Fuchsr! I will check al in your list!
Respondido : 12/10/2021 11:17 am
