Print fails with gaps when using 0.6mm nozzle, worked with 0.4
Andres
(@andres-3)
Problem
- A model that printed fine with 0.4mm nozzle/PLA, but does not print cleanly with 0.6mm nozzle/PLA. The print has vertical gaps in various places.
- All other models print fine and I have more than 300hours of print time behind me.
- To exclude any hardware issue, I used a new nozzle, new tubes all over, new extruder pulley. And followed all the tips on tuning.  And remember, everything else prints well.
What I tried
- I tried PrusaSlicer 2.5.0 and 2.6.0 alpha-5. All the same result
- The issue is worst with 0.3mm and larger layer heights. Gets better with smaller layer height. But does not really go away.
I am lost
- Is it a problem with my hardware? Can someone with 0.6mm nozzle give it a try and let me know? Print is below 10minutes and .3mf file attached in zip file
- Is it a bug /shortcoming in the slicer only triggered by 0.6mm nozzle?
- Btw, I love 0.6mm nozzle with Arachne....no, I not gonna change my nozzle back to 0.4mm just for that piece.
Comments on image
- The arrow marks the vertical gap. The image does not manage to show the extent of the problem. The vertical gap is "see through" and around 0.5mm wide.
- The black sketch on the bottom is the profile as it prints. Print direction of the left perimeter is "right to left".So more narrow at the start after deretraction.
- Printed with 0.3mm layer height on 0.6mm nozzle and Overture Silk PLA. Standard settings otherwise. And all other models I print are perfect.
My guess is that it has to to with "deretraction".
- The issue is caused (on all sides) at the deretraction points (blue). The filament extrusion is too little initially. Or delayed?
- Its worth mentioning, that arachne tries to print a 0.998mm wide perimeter with a 0.6mm nozzle. Maybe thats too much after a retraction?
debug
Model: debug
Publié : 07/03/2023 5:32 pm
RE: Print fails with gaps when using 0.6mm nozzle, worked with 0.4
save a copy 0f your prusa slicer setup, as a .3mf file,  zip compress it, and attach the zipfile, to your next post
regards joan
Publié : 07/03/2023 7:01 pm
Andres
(@andres-3)
The Prusa slicer setup (.3mf), zip compressed.
prusa sclicer setup.3mf.zip
for everyone that wants to help hands on. Thank you
Publié : 07/03/2023 7:13 pm
Stefan
(@stefan-3)
This is a delicate small part that is designed to be printed with a 0.4 nozzle.
Printing a 0.9 mm thick wall with a 0.6mm nozzle is sub-optimal.
Publié : 07/03/2023 7:22 pm
Andres
(@andres-3)
Dear Stefan
I very much appreciate your time. I agree that we should rule out the sub-optimal width. Hence, I adapted the model such that the wall you measured is exactly 0.65mm wide. What I believe to be the optimum width for a 0.6mm nozzle.
I just gave it a try. The result is the same. A clearly visible vertical gap. Exactly at the deretraction markers.
- I would even say, the gap got wider!
debug-v2-wallwidth.3mf.zip
Ce message a été modifié il y a 3 years 3 fois par Andres
Publié : 07/03/2023 11:29 pm
mrstoned
(@mrstoned)
I had a similar issue with a .8 nozzle, try painting the seam on one of the wider areas where you have multiple walls.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
Publié : 08/03/2023 5:28 pm
Stefan
(@stefan-3)
Let me add that i do not own a Mini...
What you can try:
  • i recognized that when i open your second project file, in all default profiles (Print, Filament and Printer)  there are modified settings.
    Especially Print settings>Speed >Acceleration is marked as modified? Reset this to default values.
exactly 0.65mm wide
  • to my personal taste, i would print this part with 0.2 0r even 0.15 mm layer height,
    as it is so small and it does not matter if it takes 3 min or 5 min to print.
  • to my own surprise default extrusion width on a mini is 0.68 mm, so adjust your model to this value
  • as already suggested, try to move the seam to another place on the model (with seam painting), where the walls are thicker
  • Arachne is very promising, however there were also often some strange effects with it...
    Very experienced users often suggested to switch "Perimeter Generator" to "Classic" and compare the results.
  • You mentioned "Overture silk PLA", but there are only predefined settings for Overture PLA,
    so there is a chance that this filament profile does not fit and the silk PLA would need other Linear K-settings
Publié : 08/03/2023 6:54 pm
mrstoned
(@mrstoned)
Tried the print on my mini+.
Generic non-silk PLA with a e3d 0.6 nozzle sliced on 2.5.0 on windows.
Sliced 1 perimiter, 100% infill, 0.3 profile
slice 3fm as well as gcode attached.
DO NOT RUN GCODE! only provided for debug-viewing
Not pretty, but no gaps
Publié : 08/03/2023 8:32 pm
Maciej Janowski
(@maciej-janowski)
I have the same issue, on multiple models, printing with 0.6mm nozzle on Prusa MK3S+ and near stock settings (modified brim parameters). I slightly modified LA settings, but on stock ones the problem was the same (or worse).
Example of this:
Using Arachne.
Looks like it's trying to start a perimiter after a long move
Ce message a été modifié il y a 3 years par Maciej Janowski
Publié : 10/03/2023 4:39 pm
