Please suggest to avoid this kind of misprint
atomleef
(@atomleef)
I print a sphere pot but there is a lot of glitch(i do not know the right word to call it), and misprint, How to solve this problem to print clear surface sphere? 3d file in download link below, please make suggestion.
3d file Download link
https://we.tl/t-C5gwgVn9oM
thank you
aka
This topic was modified 6 years ago by atomleef
Posted : 03/08/2020 4:30 am
Oxygen
(@oxygen)
RE: Please suggest to avoid this kind of misprint
adjust this setting, and try to reprint
set to aligned or rear
Stock MK4S with FW 6.2.6
Posted : 03/08/2020 8:24 am
atomleef
(@atomleef)
@oxygen
thank you, where can i rad about this feature more? Can this feature avoid circular misprint(in loop line, see attatchment) at near bottom of object?(sorry, i do not know exactly word)
Posted : 03/08/2020 9:08 am
atomleef
(@atomleef)
I add more image to make easier to identify the print problem, print result appear as ladder not smooth. Please make suggestion, thank you
Posted : 04/08/2020 4:41 am
Oxygen
(@oxygen)
please check all hex bolts on your X and Y steppers (2 on each)
Posted : 04/08/2020 9:19 am
atomleef
(@atomleef)
@oxygen
May i  ask, why bondtech is better than original one?
thank you
Posted : 04/08/2020 11:42 am
Oxygen
(@oxygen)
in my case the printer had under extrusion issues and issues with filament not from Prusa (horrible clogs and uneven thickness) I tried to re-adjust the heatbreak (was too low) and replaced the PTFE tube in the heatbreak that did not solve my issues. replaced the heatbreak and that solved my issues for the most part (I can print with any PLA filament in my stock) the under extrusion issue greatly improved.
Keep in mind this is my experience on my printer in my environment: your mileage may vary!
Posted : 05/08/2020 6:21 am
atomleef
(@atomleef)
@oxygen
thank you 🙂 I will collect your experience to my knowledge.
Posted : 05/08/2020 6:28 am
