PLA vs PLA+ print settings
PendingPeril
(@pendingperil)
What adjustments do you make when printing PLA vs PLA+? I print PLA 15 degrees cooler, but that's it and I'm finding that I get much better tolerances with PLA+. Prints with moveable parts tend to move freely when taken off the bed using PLA+, but the same parts with PLA are fused and need a little elbow grease to get freed up.
What other settings could I possibly tweak to get the same results when using PLA?
Respondido : 19/02/2022 1:58 am
Miembro
RE: PLA vs PLA+ print settings
No change for me between the two filaments.
Respondido : 19/02/2022 2:02 am
Same here. I use the same settings. If you see your PLA fuse, it's maybe because it's overextruding a bit. I'd run a test print and adjust my extrusion multiplier for that filament. See https://projects.ttlexceeded.com/3dprinting_prusaslicer_extrusion_multiplier.html
Respondido : 19/02/2022 12:43 pm
PendingPeril
(@pendingperil)
Wow thanks that immediately fixed it. Left is 0.9 EM and right is the default 1.0 - https://imgur.com/a/Wf6TsMB . Left was rotating freely off the bed and right is still fused.
Maybe the slightest bit under extruded so I'll play around with it, but this helps a lot. I was getting frustrated because PLA+ was passing tolerance tests of 0.15 and the PLA while looking fine, was nowhere near that.
Respondido : 19/02/2022 2:13 pm
Good to hear it worked. You can try 0.95 or so, or dial it in with a hollow cube test print.
Respondido : 19/02/2022 2:24 pm
