[Solved] Petg benchy problems
FurrySquirrel21
(@furrysquirrel21)
Ok, so this is my first real print on a Prusa mini+ with urban grey Prusament petg using Prusa Slicer. The test prints on the usb worked wonderfully with pla and I even tried petg and they still were beautiful. When I used Prusa Slicer with Prusament petg settings this happened. What should I do?
Posted : 14/05/2021 11:04 pm
RE: Petg benchy problems
@furrysquirrel21
Compare the settings in your gcode to the settings in Prusa's gcode. You'll be able to see what the difference are - then apply them in order to see what has the largest effect.
Posted : 15/05/2021 2:14 am
PETG tends to be stringy but this is worse.
Posted : 15/05/2021 4:28 am
FurrySquirrel21
(@furrysquirrel21)
I was wondering how to you get the print fan to go to full speed after 4 layers on Prusa Slicer?
Posted : 17/05/2021 7:46 pm
@furrysquirrel21
That should be doable with GCODE.  I will search for it tonight.
Posted : 17/05/2021 8:12 pm
Posted by: @furrysquirrel21
If you want it OFF for the first 4 layers, you can set Filament Settings->Cooling->Fan settings->Disable fan for the first X layers. If you want to ramp it up, take a look at Filament Settings->Cooling->Fan settings->Full fan speed at layer.
Posted : 18/05/2021 12:39 am
Thomas
(@thomas-17)
Solved?
Did it solve your stringing with the fan adjustment?
It would have been nice with som pictures from the following new prints.
Posted : 25/09/2021 9:44 am
