Override 0 wall thickness on top layer in vase mode
BernieW
(@berniew)
Hi all,
I'm trying to print a cylinder that will slide over a tubing perfectly with no seam. When I print using seams it fits perfectly but has an ugly seam.
When I print in vase mode I get rid of the seam, the bottom slides over perfectly, but the top has a gap because it has a wall thickness of 0.
Does anybody know if it is possible for me to override the 0 wall thickness at the top? I've tried in settings, but this won't allow it. Is it possible to change the gcode to do this?
Veröffentlicht : 19/02/2021 11:57 pm
RE: Override 0 wall thickness on top layer in vase mode
can you make the tube longer by the amount that you need extra?
Veröffentlicht : 20/02/2021 12:31 am
BernieW
(@berniew)
Thank you for your suggestion @JoanTabb.  I found a workaround, it took a lot of work measuring and testing, but in the end I got a good solution for my needs.
I am 3d printing an inner sleeve and then 3D printing an outer sleeve in vase mode. The outer sleeve slides perfectly over the inner sleeve. I got the idea from laminating. 🙂
It works a treat for very simple cylinders, which is what I need it for.
Veröffentlicht : 21/02/2021 3:53 am
