Leftside overhang corners fail?
Unpoor
(@unpoor)
When trying to print https://www.printables.com/model/305814-mak-vector-duct-orbiter-v20-v6-volcano-crealityend/files
the left corner on this modell is impossible to print, tried supports and not, it prints counter clockvise and I use 100mm/s perimiters, inside and outside.
Prusa mini+ 6.2 fw
Any ideas?
Napsal : 08/02/2025 12:40 pm
RE: Leftside overhang corners fail?
Check where the slicer is putting the seam.  I suspect its that corner.  If so move it elsewhere.  Also printing fast with a mini with thin geometry is asking for problems.  Slow your print speed down.
One other thing, your first layer with the brim is showing masses of drag marks, that means your first layer is squished too much.  You might want to revisit your basic printer calibration and setup.  Double check everything is still square etc.
Napsal : 08/02/2025 1:27 pm
Unpoor
(@unpoor)
Yaa I forgot about the fits layer ,, but it sticks 🙂
Also downloaded the model again cuzz it looks like the one Iwe got wasent from printables.com, resliced it and now its ok, tnx anyways.
Napsal : 08/02/2025 3:22 pm
