Layer adhesion difference on left versus right side?
MileHigh3Der
(@milehigh3der)
I have a round cup holder that I print with two perimeters that make it four lines, no space for infil.  When I was printing it, the right hand side was more flexible.  I thought maybe the STL had the middle hole not centered, so I did that again for a new STL.  Same thing.  I then took the same STL and rotated it 180, and the right side (the left side of the STL) printed was more flexible.  So I think it is a printer thing?
THoughts?
Napsal : 15/12/2025 2:45 am
_KaszpiR_
(@_kaszpir_)
RE: Layer adhesion difference on left versus right side?
Yeah, its related to uneven extrusion due to bowden tube, you can read more about it https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/2997 - it is super long.
Napsal : 16/12/2025 8:51 am
 - although it is also worth checking that your fan is clean and the fan shroud has not been damaged/dislodged causing uneven cooling.
Napsal : 16/12/2025 4:21 pm
