Issue with edges mid print + other quick layer issue!
See attached images. I recently switched to a .8 nozzle to print faster and have been running into issues with corners + areas with quick / short layers. I printed this with 0.4mm layer heights (using the prusa pre-set .40mm Quality setting). Infill @ 80%. I printed this object vertically (with the "rod" at the top being the last layers).
I used Hatchbox PTEG - 240 1st, 250 other layers. Bed at 85/90. I printed this at 60% speed to start, and gradually ramped it up to 90%. What can I do to fix this problem?
Let me know if you need any other specifics to help me fix this issue!
Thank you so much.
Publié : 09/07/2022 12:11 am
