Is it possible to print using Delrin
grabnerwg@gmail.com
(@grabnerwggmail-com)
Have used Delrin before, using long rods and cutting them on my lathe. Delrin works very well in the products I make.
Is it possible to use Delrin filament on the Mini?
Walter
Dieses Thema wurde geändert Vor 6 years von [email protected]
Veröffentlicht : 05/06/2020 7:24 pm
GrimmWinters
(@grimmwinters)
RE: Is it possible to print using Delrin
i read delrin aka pom aka acetal needs a bed-temperature of 120°C, so probably no go with the mini as we can only heat up to a 100°C. but that's just what i read 🙂
Veröffentlicht : 12/06/2020 10:19 am
Chocki
(@chocki)
Here you go: https://gizmodorks.com/acetal-3d-printer-filament/
Veröffentlicht : 12/06/2020 12:02 pm
Posted by: @grabnerwg
Walter
if you need good friction characteristics I would take a look at this filament: https://www.filamentworld.de/shop/special-filament/abriebfestes-filament/igus-iglidur-i-180-filament-1-75-mm-weiss/
...easier to print as POM.
Veröffentlicht : 12/06/2020 1:48 pm
