Inconsistent layers and gaps on the wall
What could be causing these issues on the walls outside of my print? I'm using the Prusa Mini + with Prusa Slicer, Silk PLA and 195 nozzle temp. I have "ensure vertical shell thickness" off and I tried with both 3 and 6 perimeter with no visible improvements. All other settings are set to default for Generic PLA. I also tried using the "classic" perimeter generator with "Detect thin walls" enabled and I get the same results. First layer looks good and I don't see any other visible issues anywhere else on the print.
Napsal : 08/12/2022 2:27 am
