How to print very small letters inside part?
dunbir
(@dunbir)
Hi, I'm trying to find the best options to print some small letters inside a model. I'm using a test model to play with slicing options until i can find the best way to do it. I've tried many combinations but so far I haven't found something satisfying enough. Is this model above the possibilities of mini+ or is there better options I still haven't tried?
Respondido : 12/04/2023 5:55 pm
Hello
(@hello)
RE: How to print very small letters inside part?
If possible make lettering in first layer on bed
Respondido : 15/04/2023 9:54 am
As a very rough guide:
Elephant's foot compensation settings greatly affect text facing the build plate.
Ironing messes text on the top surfaces.
Calculate fount sizes according to your extrusion width (default 0.45mm with 0.4mm nozzle) the narrowest possible line is one extrusion thick.
Yes, Arachne will compensate for this a little, but make it easy for the slicer.
So for small text choose a simple sans serif fount, measure the finest line and calculate the size accordingly.  For clean, larger, texts use multiples.
Respondido : 15/04/2023 6:57 pm
dunbir
(@dunbir)
For this test model I can't change the letter size or fount but I'll try all your suggestions with a new model later. I've tried a very small extrusion width with a 0.2mm nozzle but the result is not good. I probably used an extrusion width which was too small.
Thanks.
Respondido : 18/04/2023 12:49 pm
